Weird problem with Dash Installation Kit
  • 2
Fi_
King of Diamonds
1,697
Fryeburg
So I bought a crappy Scoshe install kit from walmart for $15 for my 02 trailblazer I got the dash apart and everything ready to be installed and I noticed something strange. The main bracket that the headunit slides into (the rectangle plastic piece.) was not wide enough for my Pioneer DEH4200UB, has ANYONE ever had this happen? I called Sound Resort and they said that that makes no sense since all headunits are the same width that are single din.
IF that's the case then why the hell did my Pioneer not fit? I don't even know what I need to get now, I ******* hate install kits D:
I thought I had a similar issue with my pioneer hu and scoche kit. I ended up taking off the plastic trim on the hu and it fit fine. You insert it from the back. I had to move it around a bit before screwing it in for the head unit to open correctly but it worked and looks great.
hmm could very well be the problem I'm used to ones where you slide the headunit in or whatnot I'll give it a go fit my last Scoshe install kit fine for my Jeep so that's why I was like wtf?
Thanks for sharing the issue and sharing how to possibly fix any future issues for others
id put the subs in a ported box, and buy the proper amp to push them
29
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
Fi_
King of Diamonds
Fi_
Fryeburg
Fi_
