What size wire to run to my subwoofer?
if u got a d2 means dual 2ohm voice coils, u can only run this as a 1ohm or 4ohm load wiring configuration, meaning with the amp u got, u can only run it at 4ohm, so ur only feeding it 500watts. http://www.rockfordfosgate.com/rftech/images/woofer_wizard/1_2ohmDVC_1ohm.png http:// http://www.rockfordfosgate.com/rftech/images/woofer_wizard/1_2ohmDVC_4ohm.png
if u had a d4, dual 4ohm voice coils, yes u could wire it down to a 2ohm load. http://www.rockfordfosgate.com/rftech/images/woofer_wizard/1_4ohmDVC_2ohm.png
the only way ur going to run that amp at full power is to run a dual 4ohm voice coil sub, or get another dual 2ohm voice coil sub and wire it in series to create a 2ohm final load. http://www.rockfordfosgate.com/rftech/images/woofer_wizard/2_2ohmDVC_2ohm.png
this amp is NOT designed to run at 1ohms. lowest impedance is 2OHM!! @1000watts rms.
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
4K
Agreed. I've used some very fine cable for +REM connections because I had it laying around and have had issues with it failing. Good quality...
5
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
trenthonda1
trenthonda1
Florida
cyn
