whats the best way to wire these amps and subs?
  • 3
tje0454
Im building an enclosure for the trunk of my wrangler. i have 2 10" Polk DXi 104 DVC 4ohm subs and 2 Alpine MRP-M500 amps. Ive never heard of strapping until an hour ago. is it something i should look into? I originally wanted to run the subs in a shared air sealed box with one sub powered by one amp.
yeah thats what i was thinking. although i heard that unless the gains were perfectly matched, as well as the voltages, it might not sound good. the box is 1.515 cu. ft. btw (subs are .66 cu. ft. in a sealed box)
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
tje0454
tje0454
Maryland
VisceralSound
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
