Whats The Difference?
MuNchiezzz
CarAudio.com Recruit
What is the major difference in sound between an enclosure with a single layer port and an enclosure with multiple layers of port? Is one better than the other? Is one maybe better for SPL and one for SQ?
View attachment 22455View attachment 22456
The more wood or material used to build the enclosure, the more sturdy it becomes. The more sturdy, the less output loss due to enclosure panel flex. Plus what they said above, longer port, lower tune.
If anything that many turns reduces port efficiency making the enclosure unnecessarily bigger than it needs to be while still having crap rear air velocity values. Only thing that balances it out is the additional strength of the enclosure.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
MuNchiezzz
MuNchiezzz
Mesquite, Nevada
Jeffdachef
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
