Which Welding Cable Brand do you prefer?
Is it alright if I use 4 Gauge power/ground wire on an amp that has 0 Gauge inputs since I’m only using half the rated power around 1250 rms? Or is that too much for 4 Gauge?
if it's good 4ga but thought u got 0 ga..
I did and have plenty but the fused distribution block I got have one (0) Gauge input and two (4) Gauge outputs. My speaker amp uses 4 Gauge so no problem but the sub amp uses 0 Gauge and can’t seem to fit 0 Gauge into the 4 Gauge output
u are still running the 0 ga to the dist block? yeah that what u do get the big wire back there and then use 2 4 ga wires to spit out to the amps..
I understand, my concern was if it’s fine to use 4 Gauge wire into an amp that is supposed to use 0 Gauge since I’m only using half the rated power
yeah it's fine, 4 ga can run a good amount of power 1 foot..
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
871
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
SoCalArgento
MmatsDude
