That's pretty much what I was thinking....There is a dyno of that amp somewhere. Think it was oldschoolstereo that did it. I believe it was like 400 watts at 2 ohms and 45-50 amps of current. Running it at 1 ohm the current will certainly go up. If you are clipping even slightly that fuse is getting over ran quick.
Your power wire can never be too big. And what are you referring to by 12-16 volts? What does the manual state this is for? Operating voltage?the manual says it's good for 12-16 volts. if that's what u mean?? but you think the power wire is to big?
yes. operating voltage.
