los33
Car Audio G
And here is another retarrd.. as for the last parts of what you said.please tell me how your going to install a intercooler line onto a bottom pan? these lines would be ripped out if you ever bottom out,or from road debries. As for threads melting bs,your transmission temps shouldn't reach above 300F, which at that temp its more than likely burning your clutches. please show me a transmission that gets hot enough to melt threads when 90% of them have rubber somewhere along their cooler lines. Also a cooler needs line pressure to cycle the fluid through, which your pan has 0 pressure.
Transmission fluid cycles thru the transmission... Then around the gearing and clutch... Then OH MY GOD BACK TO THE PAN!!!
The transmission may not be hot to the touch, but that fluid that cycles gets to the bolt causing excessive heat to solder the bolt to the PAN.
