Will I need a new battery/alternator??
  • 1
phillipc421
5
Kansas
Hey guys,
So I will be installing two Sundown SA-12's running of a Sundown SAZ-2000d into my Jeep Cherokee soon. All stock electrical. Other than the big three upgrade, will I need to upgrade my battery or alternator? I'm new to this so help me out please!
Thanks,
Phillip
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
450
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
347
phillipc421
phillipc421
Kansas
phillipc421
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
