Will I need a new battery/alternator??
phillipc421
5
Kansas
Hey guys,
So I will be installing my two Sundown SA-12's running off a Sundown SAZ-2000d into my Jeep Cherokee soon. This is my first build so I am quite the novice, but I was wondering if I will need to upgrade my battery or alternator from stock in order for the system to perform correctly?
Any help is appreciated!
Thanks
Probably, depending on your stock alternator and battery. What is the alt's rated amperage? Stock electrical usually can handle up to around 2k without big issues but depending on the age and strength of the electrical system you will probably need a big AGM under the hood and Big 3. I'd definitely do the Big 3 upgrade, though.
I would run at a bare minimum 180 amp alternator and upgrade your front battery at least.
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
7
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
450
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
346
phillipc421
phillipc421
Kansas
audiolife
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
