Will my new system work?
  • 3
luminousv2
5
UK
Hello all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As you can probably imagine, I'm a noobie, before I go ahead and install this new system I'd like to make sure it should work without blowing up.
I got 2 x 12" Sony XS-GTX121L 1000W Details :
1000 W Maximum music power
300 W RMS power handling
Single 4 ohms heat-resistant voice coil
Rated Input Power: 300W
Frequency Response: 32Hz-1000Hz
Compact design for Installation flexibility
Polypropylene Cone
Diaphragm material PP
Barium Ferrite Manget
Stroke stabilizer
5-sided Polypropylene cone for lower distortion and deeper bass
And my amplifier :
Juice JA794 - Illuminated Series 4 Channel 1500W Amplifier. Details :
Max Power Output Ratings:
Total Max Power: 1500W
RMS Power Ratings:
Per Channel into 4ohms, 14.4V (≤1%THD+N): 60W RMS x 4
Per Channel into 2ohms, 14.4V (≤1%THD+N): 85W RMS x 4
Bridged into 1ohms, 14.4V (≤1%THD+N): 170W RMS x 2
General:
Input Sensitivity: 0.2V - 6V
Frequency Response: 10Hz - 45KHz
Low Pass: 50Hz - 250Hz
High Pass: 80Hz
Bass Boost: 0-12dB
I've done a little bit of research to find what I need so...Am I correct in thinking the amplifier is not powerful enough? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Thank you in advance! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Your trying to run woofers with an amp ment for door speakers... It will make some noise but not very much lol get a nice mono block amp
Dang it. I should have figured it wouldn't turn out like I planned:( Guess I'll have to try and sell this amp to get an actual Subwoofer amp and not a speaker amp.
What I'll be looking for is an amp that is mono amp that has at least 300W RMS Per Channel into 2ohms, is that correct? If not can you advise me on what I should be looking for. I would really appreciate it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dang it. I should have figured it wouldn't turn out like I planned:( Guess I'll have to try and sell this amp to get an actual Subwoofer amp and not a speaker amp.What I'll be looking for is an amp that is mono amp that has at least 300W RMS Per Channel into 2ohms, is that correct? If not can you advise me on what I should be looking for. I would really appreciate it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just get a simple Mono-Block amp. You dont need a multiple channel amp. How much are you looking to spend
Mono block means only 1ch... But u need to know what ohm woofers you have so you know what kind of amp to buy. Most 2ch amps are 2ohm stable per channel... Most mono amps are 1ohm stable
Budget isn't too much of an issue in all fairness, all I want to do is get the right amp and cheap as possible though. So whatever is cheapest but reliable and is sure to work with my 2 subs I'll be happy. If you can link me to some or explain what I need to look for then I can do the shopping //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for your reply.
How would I figure out what Ohms my subwoofers are? It doesn't seem to tell me anywhere on the boxes D:
It says : "Single 4 Ω heat-resistant voice coil". Does that mean they are 4 Ohms?
Using a dmm on the woofer... But from the specs u listed you have single 4ohm woofers... So you want a mono block that makes power at 2ohm
Oh okay I think I understand Would that mean I would require:
Mono block amp 600RMS @ 2ohms because there's 2 subs? If it was just the one sub then it'll be a mono block 300RMS @ 4ohms because everything gets halved?
Sorry for so many questions, just trying to clearly understand it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Mono Block Class D Technology
MOSFET Power Supply
Class D Amplifier type
Max Power Output 1 x 1000W @ 4Ohms
1 x 1650 watts @ 2 Ohms
1 x 2400 watts @ 1 Ohm
1 Ohm Stable Mono Block Channel
Low pass Crossover 40Hz - 300Hz
Bass Boost 0-12dB : 55Hz
DC Input 14.4 + 0.1V
Idle Current 0.68A
Freq Response (3dB) 19Hz~300Hz
Fuse Rating 2 x 40A
Signal to noise ratio >93dB
Themral overload circuitry
Short circuit protection
Nickel Plated RCA and Speaker terminals
306mm (L) 50mm (H) 165mm (W)
Would this work ?
w
i mean honestly with those subs, this amp would do fine running at 2 ohm.
- LINK --> http://www.amazon.com/Audiopipe-APMI-1500-Compact-Monoblock-Amplifier/dp/B00T8T967M/ref=sr_1_1?ie=UTF8&qid=1457369801&sr=8-1&keywords=audiopipe+apmi+1500 -
$128 shipped new
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
500
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
980
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
993
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
luminousv2
luminousv2
UK
bgowdy
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
