wiring 4 JL w3 10s
  • 1
go to rockfordfosgate.com and then go to rftech scroll down a little and pic wiring wizard. you can then select a bunch of **** pic the one that says 4 woofer system 4ohm dvc 2ohm load this will show you how to wire it. how this helps
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
203
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
604
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
644
648
559
cmd343
cmd343
Maurice, LA
