Wiring a radio
  • 4
j_alexander
Tukee, AZ
i just wired in my new hu and wired the remotes to the constant power like an idiot keeping my amps on all night. so as a concequence my battery died, i re-wired the remotes to the switched power. i recharged the batt and it was fine for a day but now i dies after i leave the car off for a period of time. could it be a wiring problem or just a dead battery that wont hold a charge?
Are your amps on have you checked them if they are off than it could be that your battery has just bit the dust. BUt turn your car on take a dmm and see what your are reading on your battery while its running if its 13 or more than your charging is good if not than there might be something wrong.
Chances are you killed your battery. Check to make sure everything is powering off when the key is off. If everything is powered down properly, then take your battery to Autozone to have it charged and load tested.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
219
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
623
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
662
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
654
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
563
j_alexander
j_alexander
Tukee, AZ
loopkiller
