Wiring a radio
  • 4
j_alexander
Tukee, AZ
i just wired in my new hu and wired the remotes to the constant power like an idiot keeping my amps on all night. so as a concequence my battery died, i re-wired the remotes to the switched power. i recharged the batt and it was fine for a day but now i dies after i leave the car off for a period of time. could it be a wiring problem or just a dead battery that wont hold a charge?
Are your amps on have you checked them if they are off than it could be that your battery has just bit the dust. BUt turn your car on take a dmm and see what your are reading on your battery while its running if its 13 or more than your charging is good if not than there might be something wrong.
Chances are you killed your battery. Check to make sure everything is powering off when the key is off. If everything is powered down properly, then take your battery to Autozone to have it charged and load tested.
I agree with this ^^^ Visit Critchfield and get a vehicle specific adapter for your car/system. I have a pinout for the connector at the factory...
29
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
441
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
499
554
494
j_alexander
j_alexander
Tukee, AZ
loopkiller
maylar
    Jun 2, 2024
    Jun 1, 2024
