Wiring dual alts
Just get a new 2 pin plug and wire it in parallel to the factory plug. I cut the plug off my 04 blazer and wired it with the factory on my 03 yukon to run dual alts.
That's what I was thinking but 05 and up gm switched to pulse width modulated signal wire. So I don't think that'll work
Sent from my Pixel XL using Tapatalk
I can send my mechman alternator to get the regulator swapped out for $43. Then I can just use this as a secondary.
just have them send you the regulator if you have to pay shipping. it's easy to swap out
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
186
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
592
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
626
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
642
basketball00011
basketball00011
Fond du Lac, WI
wew lad
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
