wiring two switches for one led?
sb220
VA
Im working on installing LED strip lighting in my truck camper shell and would like to have a switch in the cab and rear of the truck to switch on the same lights.
I can wrap my head around wiring them up in series, creating a "master switch" closest inline to the battery.
However, Im wondering if its ok to wire them up in some kind of parallel....
+--switch
..............\___ Light
+--switch
Is that the way to do it or would it require diodes to prevent backfeed....can a power source actually backfeed on itself?
Thanks
Your switches need to be SPDT. You wire them like this...
Now either switch will toggle the state of the LED strip
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
190
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
599
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
639
647
555
sb220
sb220
VA
sb220
