WTTF: Need a 5 channel amp!
  • 5
WashYourWinky
The Pilot
Okay I'm in need of a 5 channel amp! My 4 channel is acting up and I've been wanting to downsize anyway.
I have a few things I could trade. I have more pics of all the amps.
Arc Audio KAR-900.1D mono amp
Cosmetic 8/10 Mechanical 10/10
Specs:
900.1
1 x 350W @ 4 ohms
1 x 750W @ 2 ohms
1 x 900W @ 1 ohm
Fuse: 3 x 30A
Crossfire CFA-202 Cosmetic 7/10 Mechanical 10/10 and a Crossfire CFA-142 Cosmetic 10/10 Mechanical 10/10
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
146
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
109
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
454
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
348
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
759
WashYourWinky
The Pilot
WashYourWinky
Cincinnati, Ohio
WashYourWinky
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
