XS power AGM d4800 to xs power titan 8 lithium.
  • 3
MikeyD812
CarAudio.com Recruit
I bought a XS power D4800 for the front of my truck. It has 2 runs of 2/0 running to the back to a XS power Titan 8 lithium. I have a mech man 370 amp alt that I am installing. I have read that these are compatible, but the lithium will drain the AGM a little if not ran or charged much. This is my daily driver so I don’t think this will be an issue. I was looking at the XS power chargers for the lithium as they do not come 100 percent charged. Is this charger something I can leave hooked up all the time or will it need isolated to just charge the Lithium?
You generally do not want lithium to sit around at 100% state of charge. Wherever it's charged when it is delivered should be fine to just plug and play or for long term storage.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
430
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
337
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
698
MikeyD812
MikeyD812
Mitchell Indiana
MikeyD812
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
