XS Power D5100R Battery
  • 2
Nut Hair Trick
Pubes
XS Power D5100R Battery: Used under the hood of my car for less than 2 years. Sold the car and it has been on maintenance charge for the last month.
12V BCI Group51R AGM Battery, Max Amps 3,100A, CA: 745, Ah: 60, 2000W / 3000W
Weight Lbs. – 39.60
Weight Kgs. – 18.00
Length – 9.04 in
Height – 8.19 in
Width – 5.43 in
MAX Amps – 3100
CA – 745A
RC – 100min.
Ah – 60
$150 Shipped:
Shipping and Miscellaneous Item Information: On Me. Unless you live in Cali or New York, add $10
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
470
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
697
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
510
Nut Hair Trick
Pubes
Nut Hair Trick
Arlington, Tn
Nut Hair Trick
    Jun 1, 2024
    May 31, 2024
