FEATURED Hyundai Cilantro.. I mean Elantra!
I just spent the last 3 hours looking through all my "car audio" stuff in several locations around the house for 3 pairs of 3 feet long RCA cables. The cables for connecting my two RF Punch amps to the AC DSP. I found them... guess where they are. In the car, connected to the DSP lol. I forgot I put them there so I would not lose them.
Just ordered a 10 pack of 200a ANL fuses. The JP13 suggest a 200a fuse for it so I think 10 will do me for a while. I am going to run a 0awg from the ioxis group 31 in the trunk directly to the inline fuse then right to the JP13. While I was in the trunk looking for my RCA's I noticed my amp rack/board collapsed and is just basically laying on my sub box. It is held in place by the front brackets x 2 but I have been struggling to find a solution to keep the rear of the board raised so that it angles the amps towards the opening of the trunk. The rear is supposed to sit about two inches higher than the front side.
Got my ANL fuses. SKAR brand so I won't mind blowing them lol.
I have everything finally to finish the install.
Uggggg!!! I just ordered a smaller overdrive pulley for my H.O. alternator. Driving is fine but at an idle, with the air on, in the heat... she be lackin! The Power Bastards alternator I have is a direct replacement with a stock size pulley.
So I hit a deer a week ago, broke my right headlight housing, ordered a new set, installed them, drivers side was defective, ordered the replacement, just installed the replacements and they look perfect in the car. Later tonight I will travel to a flat area with a wall and adjust my beams.
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
ThxOne
Premium Member
The Transporter
ThxOne
The United States of America
ThxOne
    Sep 9, 2024
