I understand that. I want to know can I use one of the 2 bolts (the alt bracket bolts) to connect the wire to.I am sorry, but i can't help but laugh at your question.....the ENGINE BLOCK is what is being referred too!! If you have no clue what an engine block is, you should not open your hood
if either of them go into the block, which most likely they do, then yesI understand that. I want to know can I use one of the 2 bolts (the alt bracket bolts) to connect the wire to.
hrmm... read much?any bolt will do (as long as you dont take something apart and fvck it up). i used the alt mounting bolt.i release myself for liability if you fck something up.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif nopehrmm... read much?
can you not crimp some ring terminals, and unscrew some bolts? it's that easyanyone in ohio know how to do the big three and wanna do it for me???
nope, nat two smort amm ican you not crimp some ring terminals, and unscrew some bolts? it's that easy
did you install your system? this is way more easier //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifi just dont trust myself to do it
