Help designing a dual 8” ported box for a BMW Z4 E85
  • 2
Zedfour
Hi I’m New to the forum and I’m desperately trying to build an enclosure for 2 x powerbass xl-840d 8” subs. The problem is, I have a 2008 Z4 roadster...
I’ve custom fabricated the dash and installed a pioneer avh-8500bt double din, I made tweeter pods for the A pillars and have 3 way hertz energy/ audison prima mixed components front stage run off a Helix B4 blue 4 channel & alpine 6 x 9s custom built in the rear cubby holes run off the hu.
ive removed the rear shelf so the trunk isn’t sealed!
the subs are 200 rms each and I have a massive audio b2 nanobit to run them @1ohm
is there anyone who can help me with what size enclosure I need? The max size I have is 32” width 12” high and 14” depth
would they be better firing up, port back? This is the sub spec
It’s a convertible, 32” width 12” height 14” depth is the largest dimensions I have to work inside
EBP on those subs is about 80 which indicates that a ported box should be used. I don't like the fs being so high at 52hz, don't expect much below 40hz with those.
I would go with about .6 to .75cf per sub and tune them around 40-42hz.
Thanks, I’ll see what I can come up with. If it sounds like mud, what choice of sub for such a small space would you recommend?
I want to try my hand at a ported box for one IDQ12. I built a sealed box a few years ago and it sounds good but I want to see how ported...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
172
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
192
424
Zedfour
Zedfour
THATpurpleKUSH
    Apr 27, 2024
    Apr 27, 2024
