What RMS should my amp have when paired with a Kicker Comp R 10" DVC 4ohm (48CWR104) sub in a BRZ?
Going to connect the DVC in parallel to form 2ohm at the amp.
Well that speaker ask for 400w rms. I would tell you or recommend to you at least a 600w RMS amp at whatever ohm load you plan to run it at. Being that you said 2 ohms then 600w RMS @ 2 ohms would allow for headroom and clean power to the sub.
You could use a 1000w or more if you want too, just make sure the gain is set correctly.
Thank you, i will get an amp with a higher rms rating
Those Pioneer amplifiers are really nice and make more then what they claim RMS. I have their 4 channel version running right now as do many others in the car audio community. Those 4 channels and the mono-block version are nice solid amplifiers with a good reputation.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
958
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
yazitron
yazitron
Sydney
Firewalker
    May 22, 2024
    May 22, 2024
