Rockford fosgate p3d4-12’s
Andypeck79
Ca
I’m currently building a system in my 1993 Ford bronco with my daughter. Unfortunately I had a stroke 7 months ago as we where starting to build. Right now I have 4 fosgate p3d4-12’s in a sealed box not meant for these subs. The bass hits extremely hard, but it’s not that ground shaking bass u can hear coming a couple blocks away. It’s just a hard direct bass. Can’t really describe it. I have a fosgate 2500bd1cp. Can someone help design me design a box that I can build with my daughter. Unfortunately I do t know the differences in all the different styles and I have a hard time grasping them all. My current box is 49x30 by like 18. But my current box is meant for 6 that was the plan before the stroke so I’m limited on funds now. Pictures of box now. And specs of subs. I want that low bass u can hear from a distance. Any help would be greatly appreciated
Another stroke survivor, I had one as well and over 6yr later I am still in recovery.
Once I got out of rehab trying to learn design became something to fill all those idle hours late at night.
I can possibly help out, this will get loud and low and I think it'll fit your vehicle too. If you're interested in this design, one similar or something totally different just message me and we'll go from there.
That look’s perfect. And yes dimensions would work.
I never knew that. Thanks for sharing. Thanks again for designing my box.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Andypeck79
Andypeck79
Ca
Bobbytwonames
    May 19, 2024
    May 19, 2024
