Rockford Fosgate P3SD2-8 - Wiring - Factory JBL
  • 2
noveske
Anyone familiar with the wiring schematics of the JBL amplified systems?
Not sure if I wired this correctly. Was aiming for 2Ω assuming the factory amplifier outputs a 2Ω load.
Comparing with the wiring wizard on the RF site, I didn't see one that matched.
Grabbed the 2Ω sub. Maybe I should have grabbed the 4Ω and just paired the positive and negative and just ran 2 to each? Like this?
Any guidance? Thanks.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
noveske
noveske
Central PA
noveske
    May 16, 2024
    May 16, 2024
