JBL GTO629 + JBL SUBBP12AM install?
Morgasmo
USA
Hello, I have just installed 4 JBL GTO629 6.5 speakers to replace my stock Beetle speakers and also purchased a JBL SUBBP12AM for the trunk. I’m also considering the JBL Club tweeters.
I’ve ran the Boss wiring kit from the battery and I’m not sure what to do from here.
Also I have no idea if I need the 4way amp for the GTO speakers or not but I’m using an android radio head that has very little boost for sound.
Do I wire the sun by itself and reserve its amp for the 12”?
Where can I wire the smaller amp for the 6.5 GTO speakers, can I wire into the existing speaker wires to connect to the amp and then give it power, memory and ground? Or is there a way to piggyback off the sub?
Do the tweeters also need to be powered by the JBL studio amp?
What is the best way to utilize this setup?
Thank you in advance!
I would STOP what you are doing atm if you do not know the next steps. Save your gear..LOL. Do you have a friend or father or someone with a little knowledge of vehicle Electronics that can help you with steps provided? Make sure you dont have that power wire LIVE atm. Disconnect at the battery for the time being. Connection will be last!
I’m asking for help because I don’t know the specifics on how to hook this system up properly, however can figure it out. I just figured I’d ask the professionals. I’m 44 my father is deceased. But perhaps I’ll give my mom a call. Lol
Need the Link/ Specs of the Android Radio/HU. What car or vehicle/Truck?
2000 VW Beetle.
Let me do a little more research on the HU. I dont see what Im looking for from this link. May be a bit, or in the morning.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Morgasmo
Morgasmo
USA
