So i have 2 skar zvx 12 V2 d2 and I bought a
Taramps HD 3000 2 Ohms Class D Full Range Mono Amplifier. I'm unsure why isn't it bumping loud and strong. I have it wired series parallel it should be 2 ohm final load at amp.. I could get s bigger amp if that's my issue or a better box.? I have a sealed box. The subs are rated 1500 rms and max peak 3000. It could also be my battery not being strong enough.? I have a power distribution block that runs from my battery to the block that goes to my 3000watt amp and my 1000 watt thats connected to my speakers and my music is going thru a aux to rca that runs to my 1000 watt amp to hear music. And then I have some rca wires running from that 1000watt amp to my 3000 watt amp rca to receive the music . Still waiting on my aftermarket radio. I fried my 4500 watt 4 channel amp that powered my speakers perfectly fine with my stock radio have no idea what I did to the radio I fried it a while back messing with some cables back there and my amp is now stuck in protection mode.
