2 JBL GTi1200 aka 2206 subwoofers
  • 4
Wingman0121
1. Product:
Two old school JBL GTi 1200s
2. Specs:
They're from the early 90s and the serial numbers are only off by 5 so they're also from the same batch. 4 inch coil, not much for xmax (7.6mm) so it likes a large vented box. It shares the same basket and magnet as their 2206 pro audio subs; these have a different cone (very stiff!) and perhaps a different coil.
3. Description/Condition:
Both work but I do think they need a recone. One sub's impedance (the one that has blemishes on the cone) reads fine but it has a rattle if you tilt the sub a certain way, it is not rattling as of right now. I cannot get a steady impedance reading on the other one although they both move exactly the same when I play them free-air. Again they do work as-is with no coil rub or anything. Recones can be found if you do an eBay search for JBL 2206 and they run for about $90. The previous owner drilled some extra holes on one of the sub's basket, not sure why. Technically you can recone these into 2206s and have a pair of straight SQ subs or one of the best midbass drivers around (they go for $450 a piece on parts express).
4. Price: :
$150 shipped w/tracking for both, $100 if you come pick it up. These are heavy.
6. Pictures:
(Sorry no name in pic for now, also posted on caco)
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
Wingman0121
