4 Gauge power wire capacity
Yes, but if u plan on ever upgrading just do 1/0 and get it overwith. Most will say the same...
If you do plan to stay at 1k 4ga is fine
I do agree. I went with 4 gauge and I after about 2 months I wanted to upgrade. Lost about $40 in all after selling my 4 gauge, since it was used.
I say what you run to your amp run from your alt. Keep them the same size and you will be fine. More than 1000 watts on a 4g wire you may reach a current limit and will heat up the wire. Should not be a fire issue but may lose some power flow from A to B.
MLA
So you guys run 1/0 gauge all the way from the power source to your amp? You dont run 1/0 to a fuse/distro block and then run 4 awg from there to the amp?
  • Locked
COMPLETED 4 gauge OFC
These guys got it all. https://www.acdcwireandsupply.com/MTW_4_AWG_RED_MACHINE_TOOL_PRIMARY_WIRE_p/mtw-4awg-red.htm
Nope, just purchased and received it for my brothers "74" Ford Currier truck resto build. Small 4 cahnnel taramps and a set of nice 6.5" Pioneer Z...
12
JeffM
JeffM
NL, Canada
missinglink
Decebal
    Jun 10, 2024
