Adulbrich's next vehicle/build
Have you priced a lexan windshield or door glass. Seems like you want a burp car, Ive been in daily driven cars suvs that are stupid loud and didn't have half of that stuff.
I have priced it out. Four sheets of 1 inch thick 12" by 12" squares cost me $132, with expedited shipping. I don't think that's too bad. I'd do the windshield in two pieces.
Not walled, subs up port back. You could fit two 18s sub up port back depending on how big of a box your 18s need. My next build is going to wall it to see what it does. As far as alts I'm sure you can make it happen but they don't sell kits for it like that. Uses the same motor as a civic and crx of that same year iirc. D16a1
Looking for something good to wall
Civic and crx have higher peaks which is good for burp cars. No room for alts. And two door tahoes are rare in nice conditions for a good price.... Just get a four door Tahoe or burban for cheap...
Your truck already has a salvaged title! Cut that bish up. WALKTHUR!!!
Room for alts is a must!
**** it up and wall the truck. You won't ruin the interior if you do it correctly. You can buy replacement carpet and headliners pretty cheap with better material than stock anyway.
99-06 GM full size vehicles are the perfect platform to get loud in.
Mine is an 07
Mine is an 07
Then it's an 07 classic which is the same as a 00-06.
It's silly to spend money on a second vehicle when you have a prime candidate sitting in your driveway that's already started on.
In Illinoise you dont need AC so use that spot in a CRX for extra alternator ...
So you want to spend all this money on cr4p thats not needed when all you need is to deaden your truck?
My truck is 80% deadened all inside and my panels are fine.
Headliner shakes, but because i removed the back clips that held it in place.
Only thing thats been getting torn up and destroyed is my a-pillars and rear view mirror.
Sent from my draconis using Tapatalk
Yes, lots of movement by the rear dome light. The plexi wall is going there.
Besides drilling two holes in the corner of the bed (which were smaller drain holes), I haven't cut up my truck. I don't want to.
I want another vehicle I can cut up. Going to weld the passenger door of my next vehicle shut, all plexiglass windows/windsheild, and pout concrete on the floor
sounds like it'll pass inspection no problems!
You're not building an extreme vehicle, so why treat it like one? Plenty of people are doing 160s without all of that nonsense; there's no need for all that with 2 subs.
It's not prime for what I want to do
You don't get it
Fuck the police. What inspections?
I would like to build an extreme vehicle
Just a stripper pole, some weather strip foam tape, deadener, fiberglass and matt and gorilla tape can do wonders.
Here's a look
Not doing a stripper pole in the truck. I'm not going to drill into the roof.
I don't see you doing that with your van
Buy a smart car and use my 21 //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
You don't get it
What's an extreme vehicle to you? Because you should go step by step. First you need to
Break a 150
Then a 155
Then a 160
Then go extreme
From what I can see, that cable will not work at all, as the A&K only has balanced and unbalanced analog outputs. No digital available. No...
962
Too little power won't smoke a sub...a clipped to hell signal from not setting the gain right can though...
27
1k is iabout the upper end running off stock electrical...and if you don't have the available power for your amp then it really won't hit rated...
12
I know i know another one of these dang threads. I sold my 2 12" xv3 sundowns, they hit good and plenty loud but not enough spl for me. Im going...
Fi 4.12's. Any thoughts? SEMA Showdown this weekend. This is a daily driver. 180+.
adulbrich
Olive oil un-virginer
adulbrich
Ames, Iowa
adulbrich
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
