Alpine ERA-G320
  • 2
CaminoStone
CarAudio.com Newbie
EU
Hello. I bought a used Alpine ERA-G320 digital processor. There was no 13 pin connector on the cable connecting the control unit to the main unit (on controlunit side). I bought the connector, but I don't have a wiring diagram to connect the individual wires to connector contacts. If someone can provide me with a wiring diagram of the 13 pin connector, please provide it to me.
Thank you and best regards
ooohhhh, that is going to be a very tough ask. I've had a few ERA-G320s and it's a bummer that someone cut the end of the cable off.
I believe it is a throughput cable, so you would just use a DMM to measure continuity between each wire and each pin on the other end, and then build the map.
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
239
This weekend I will be taking actual pictures for other sites. So grab it before its gone
6
657
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
5
603
CaminoStone
CarAudio.com Newbie
CaminoStone
EU
keep_hope_alive
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
