Can someone please tell me whats going on with my amp
when the amp was still connected to the battery it was reading 2.4v and when i disconnected the power wire from the battery it was sitting at 2.37 and this is at the dmm set at dcv. this is also with the car off and the remote wire disconnected. i'm about to check again right now and i dont have another amp but i might be able to borrow one from my friend since his system isnt being used right now so ill try that
its a innova 3320 and i just measured again and with the power out it just jumps around in mV and with the power connected it does the same thing with the car either on or off but i think i need to reconnect the remote and then try
Explain this part, what is "it"? You disconnected the amplifier then measured the voltage on it's terminals? Why?
This makes sense, it sounds like your not getting any power at all to the amp. Check your fuses and connections. A DMM will usually read in mV and jump around a lot when it has nothing to measure (i.e. no voltage in the wire)
iv checked all the fuses multiple times none are blown and with all the wire connected its reading 2.4v again for the amp. could it just be that the amp is dead?
If you disconnect the amplifier does the voltage reading on your power wire return to 12V? (note I said on the power wire itself, not the amplifier, I'm interested in what kind of voltage the amplifier is seeing but want you to remove the amp in case it's shorting.
Wow, we be all over the map here! LOL
You have the amplifier in the car, and there are three power lines going in - one for hot (red I hope), one for ground (black I hope), and one fore remote (blue I hope). I like to follow convention if its not obvious. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
My understanding of the above is that with the amplifier installed, you see 2V between the red and black wire? If that is the case, as already stated, something is bad in Denmark. Or Piscataway as the case may be. That should read battery voltage. If it does not, it is because something is on fire (I'd think that oyu'd report that), or because the main fuse is bad, and you are reading back-fed voltage (which means something else is bad).
What they want you to do is to slide the red wire out (do NOT let it touch anything), and then read the voltage from the end of the now-exposed red wire and the black wire in the amp. Is it still 2V, or do we have 12V now?
Next, test using a known good ground (body panel somewhere with a clean exposed bolt. Put the black lead from the multimeter on the bolt, and the red lead on the end of the red wire. Still 2V? Or maybe now 12V? Or maybe millivolts?
If 12V, you have a bad ground.
If millivolts, you have a bad fuse in line with the main power lead (yes, you checked them, that's greaaat). ;-)
Report back.
yea when i checked the voltage of the wires it was in mv and jumping around, so that means i have a bad fuse?
Yes, use your DMM and start working your way back toward your battery with the red lead. Start closest to the amp, so go to the first fuse and put the red DMM lead on the side that goes toward the amp (it will probably still be in mV) then try the other side. Eventually as you work your way back to your battery you'll find a spot where you you have 12V, that's where your problem is (most likely a fuse). Fuses can go bad/blow without showing ANY visual indications so if you spares (which you should) try swapping them out.
yea the voltage is 12v before the fuse so i think it is blown, didnt kno it would be without any visual indication tho. Im going to switch it out hopefully it works
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
4K
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
suteman
suteman
Pway, NJ
ngabria1
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
