CDT Audio DSP4.8 Amplified Digital Signal Processor
  • 4
trumpet
Barry Schanz
View Listing
Features built-in 4 channel class A/B full range amplifier output + 2 channel Class D High Power amplifier for subwoofers.
Including the DSP and amplifier in one chassis opens up many system configuration possibilities that traditionally have required more equipment, more space, more wiring, more $$$.
Connect to your Windows PC with a USB cable. Auto-detection makes for a painless connection.
Technical Specs and Dimensions:
  • Power input voltage range 9V - 15V
  • Inputs 4 x High Level(Speaker Level) In and 2 x RCA In (4V Max)
  • Outputs 6 x High Level Out, 4 x RCA Out
  • RMS Power 30W x 4 @ 4 Ohms
  • RMS Power 50W x 4 @ 2 Ohms
  • Sub RMS Power 80W x 2 @ 4 Ohms
  • Frequency Response 20 Hz - 20 kHz (0.5 dB)
  • DSP Bit Depth 48 Bit
  • A/D and D/A Converters BurrBrown
  • S/N Ratio >110 db @ 1 kHz 0.1 dB (THD)
  • Channel Separation - Low level outputs >85 dB (1 kHz)
  • Distortion(THD) >0.001% (Low Level Out)
  • Micro USB PC Control Input
  • 360 degree phase adjustment
  • Adjustable crossover frequency and slope
  • 10 bands parametric or graphic Input EQ
  • 15 Bands Per Channel parametric or graphic EQ
  • Dimensions 8.5" (215 mm) x 5.7" (145 mm) x 2.1" (54 mm)
trumpet
Barry Schanz
trumpet
St Cloud, MN
Firewalker
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
