AnthonyO 10+ year member
Budget Banger Connoisseur
Thanks man. Ill, be checking that out!! I want some those 2" Mid/tweets!! I need stop buying stuff.!! !!If you haven’t looked yet
CDT has 50% off sale right now
I have these in my doors in sealed pods. I kinda wish I had bigger pods though. There isn’t much in the way of ts specs on these. How would these sound in a ported box shelf system for midbass? Say a 45-50 HZ area tuning with a HPF at just below port tuning?Some must haves from this sale :
HD-M6+ pair at $114. 12 mm of xmax and these babies go deep! I was involved in the very first prototypes of this driver. Run with the wide bands in a two way or in a 3 way setup, these are excellent when run sealed. They also make epic drivers for a ported bookshelf setup in the house or garage!
ES-06+ pair $129. Also with 12+ mm of xmax and a copper shorting ring, these are similar to the ones above but can reach higher frequencies better and do have better midrange sound.
Wideband and unity drivers. With the ES-02A at $99 and the unity drivers starting at $114, these are a must have. I remember all the back in 2004 cdt was working on designs like these but they never came to light. They invested into their 4” offerings instead and brought the ES 07 series which was absolutely incredible. I ran the 3 way setup at the time which cost a ton of cash but was one of my all time favorite sets. Wish I never sold those . Let me edit this to add since this set is bringing back some epic memories right now, I had those 3 ways run off a Phoenix gold MS1000ta on the front channels which bench tested at 280x2 rms at 4 ohm with the rear channels bridged at 4 ohms to make over 1000 rms to a pair of TC9 motored 12” subs run sealed. That setup sounded so sweet
CDT Audio CL-69SUB CF
www.cdtaudio.com
Yeah. I have them in sealed pods as midbass, but I’m going to do some fiberglass and run dual 6.5s instead. I was thinking of using the 6x9s for a bookshelf speaker to pair with a sub, or a high powered BT stereo similar to this one with a side port.You are running the cl series 6x9’s currently in sealed pods and wondering how they will do in a bookshelf setup ported? I remember in the early 2000’s cdt started development on some 6x9 offerings. There was a prototype I had that used cast frames, similar motor to the ES-06+ but the gap depth was a little deeper, same diameter coil but increased winding width for more xmax. In the bass department these things pounded for 6x9’s lol. They never brought them to market as not many would have spent the money for a 6x9. That 6x9 you linked is more geared toward IB use. If I had to guess, to use it in a ported style enclosure you will want .5 cubes each and run them no lower then 45hz. They should do decent in this application but the Es-06+ drivers in an enclosure just like that will definitely impress! I use to be blown away how low they could go. With the es-02A’s it would make for a sweet setup! Just be sure if doing this in a bookshelf (Or a sealed door pod) you separate chamber them as the es-06+ will move way too much air around for the 02a’s cone to handle.
Nice find. Those are some good mids.Looking for a 2" mid? Just got these off eBay, $133 shipped!
Infinity KAPPA203S 2" (50mm) Silk Dome Midrange with Bandpass Crossover 50667376932 | eBay
Find many great new & used options and get the best deals for Infinity KAPPA203S 2" (50mm) Silk Dome Midrange with Bandpass Crossover at the best online prices at eBay! Free shipping for many products!
I'm excited! Love the use of the larger Morel, hate the price! I've not found anything bad about these drivers and have heard some of the upper Kappa lines in the past and was pretty impressed.Nice find. Those are some good mids.
Yeah. I have them in sealed pods as midbass, but I’m going to do some fiberglass and run dual 6.5s instead. I was thinking of using the 6x9s for a bookshelf speaker to pair with a sub, or a high powered BT stereo similar to this one with a side port.View attachment 54841
