CDT Audio HD-6 Reference Mid-Woofers 6.7"
  • 1
trumpet
Barry Schanz
Look at this on eBay http://www.ebay.com/itm/332404434296
New, 1 taken out for photography
I believe the mids are critical to an awesome experience of blissfully enjoying your favorite song in the car.
When piecing together a car audio system to get it just right you need to be selective. Whether you're doing a 2-way or 3-way front stage these HD-6 mid-woofers are a solid foundation.
Message me to schedule your 1-on-1 consultation to map out your entire system.
Rubyservsales.com
See my other listings for a recommended companion product - F.A.S.T. Rings 6.5
HD-6
1 pr 6.7" mid-woofers*
Technical specs and contents:
Frequency response: 55Hz-6,000Hz
Power handling: 100WRMS (200 watts Pk) HPF 120Hz
Mounting depth: 2.75"
Cut out diameter: 5.87"
Cast frame: OD 6.75"
Cone: Reinforced mix fabric carbon compound
Magnet weight: 20 oz
Cone surround: Butyl rubber
Impedance: 4 ohms
Sensitivity: 93.1dB
Voice coil: 1.5” (30mm)
Fs: 78.5Hz
The Award winning HD-6 component driver*with “Contoured Dispersion” provides the ultimate solution to the sonically intense reverberant field car audio environment. The HD-6 Contoured Dispersion door mounted woofer produces a sonic image that virtually appears “right in front” of you. It offers maximum sound definition with a minimum of drivers. This means it’s also very easy to install. Simplicity at its best.
HD-6 is audiophile competition quality and literally shapes the sound so it appears where it’s supposed to be. Up front and on the Beat. Critical ears have turned to the HD-6 award winning woofer and you’ll be a believer too.
1 Year Limited Warranty
Free ground shipping
These have been used for a few months and then were pulled for pro drivers to take their place for more output. These are 4 ohm drivers and in...
https://www.cdtaudio.com/cdtnew22/ms.php Real good pricing.
22
https://www.cdtaudio.com/99page.php Great deals going on for those looking for some great speakers. Just thought Id share
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
