trumpet 5,000+ posts
Barry Schanz
CDT Audio HD-6CF.2 6.5" 2 ohm Mids
2 pairs available
NIB
Cast 6.5” Carbon Fiber audiophile mid-woofer
CDT introduces HD-6CF, incorporating a new parametric blend in an affordable package that puts deep, sweet, enhanced bass and midrange response in your vehicle. Suitable for enclosed or free air use in your vehicle, these drivers provide full, rich, bass below. The may be simply mounted in a panel or deck with or without a sub-enclosure.
The air load is provided mechanically in the suspension or may be augmented with a back load by sub-enclosure. Designed and built to deliver accurate, natural, clean and smooth performance, never heard before from a 6.5” driver.
The HD-CF Carbon Fiber series enhances smooth bass and clean mid without the high cost - the pleasure without the pain.
Technical specs and contents:
If your application is not unusually restricted on depth I have other CDT mid-woofers that will handle more power, especially if you can fit a 3" deep woofer.
$100 shipped to the lower 48 states
$190 for 2 pairs
Worldwide shipping is available. PM me for a quote.
2 pairs available
NIB
- 1 pair 6.5” Cast Carbon Fiber cone woofers
- Frequency response: 65 Hz - 6000 Hz
- Power handling: 80W RMS each with a HPF 120Hz
- Impedance: 2 ohms
- Sensitivity: 90.56dB
- Mounting depth: 2.4” (61.9mm)
- Diameter: 6.5” (170mm)
- Cone: woven carbon fiber
- Magnet weight: 20 Oz
- Cone surround: rubber
- Voice coil: 1.0” (26mm)
- FS: 65.27Hz
$190 for 2 pairs
