CDT Audio MX-369/pod 3-Way Components
  • 1
trumpet
Barry Schanz
1 set
3-Way Components
Some items removed from the boxes for photos. All are new.
Description
Tech specs:
  • Frequency Response: 30 Hz - 20,000 Hz
  • Power handling: 200W RMS estimated
  • Impedance: 4 ohms
  • Mounting depth: 3.5" for the 6x9
What makes you think an audiophile quality 3-way system is out of your grasp? Too complicated? Labor intensive Factory speaker locations are restrictive?
CDT Audio MX-3 Systems install effortlessly and get you on the fast track to audio nirvana in the car. How Is It So Easy?
The 4 Facets of MX-3 3-Way Systems
  • Flexibility. We can't stress this enough against competing systems. These systems can be tailored for anything you want, even as a 2-way that can be upgraded to a 3-way.
  • The most powerful and flexible 3-way/2-way crossover on the market, the MX-1000SX.
  • The incredible 2" mid/tweeters, available in flush mount or pods. Quick installation onto the kick panels or in your factory midrange location.
  • 1" Imaging tweeters that install with literally zero holes to drill.
CDT Audio engineers have created an engineering marvel which opens the door to unique and easy installation of a variation of front-mounted 2 or 3-way systems using a mix of speaker components, adjustability, and tuning you've never been able to do before.
The MX-1000SX ultra flexible EQ module will act as a 2 or 3-way crossover depending on your specific system installation. This unit is specifically oriented to the use of very small 2~3 inch midrange drivers in a two or three way system. This unique crossover marvel offers interactive crossover and adjustability of the mid-range and tweeter, and a switchable conventional second order or high-tech elliptic 5th order filter to cross over the tweeter.
This dual-order tweeter crossover highlights the new and unprecedented functionality of this unit.
Contents:
  • 1 pair HD-690CF 6"x9" subwoofers, 3.5" mounting depth
  • 1 pair ES-020 2" pod mid/tweeters for surface mounting on the kick panel or door panel
  • 1 pair WS-100i 1.1" silk dome windshield mount tweeters
  • 1 pair MX-1000SX 2-way/3-way flexible crossovers
Check the mounting depth available for these 6x9s. You will need 3.5". Many vehicles do have trouble fitting these. I have a 3.25" deep 6x9 sub in stock to substitute if needed. If that won't fit we need to go down to a round 6.7" driver. This is typically the most complicated part of the installation.
$599
Shipping is free to the Continental US.
Factory warranty of 1 year, upgradeable to 5 year warranty for $10
All product is the latest from CDT, hot and fresh.
Ships from North Dakota.
Something to sweeten the deal, various tweeters to customize your own 3-way system:
2" flush mount mid/tweeters to substitute for the pods
These have been used for a few months and then were pulled for pro drivers to take their place for more output. These are 4 ohm drivers and in...
https://www.cdtaudio.com/cdtnew22/ms.php Real good pricing.
22
https://www.cdtaudio.com/99page.php Great deals going on for those looking for some great speakers. Just thought Id share
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
