no. they are all DVC.. he might have been running that ZX at 1ohm and getting a ballscock load more power than he thought.
or the fact that those 15" L7's aren't even seeing 1000 watts each... unless that 2500zx does 2500@2 ohmsthere is nothng I see that you have done that should have given you a big decrease in volume. This has to be a setup issue
most zx/kx2500s do 2.6-3kw @ 2 ohms and most are just fine at 1 ohm //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifor the fact that those 15" L7's aren't even seeing 1000 watts each... unless that 2500zx does 2500@2 ohms
I wasn't intending on going full blast until i get a new alternatorROFL and you think a collossus will work without a beefed up electrical? i know you have batteries and 1/0, that means ****. you are going to be needing an alternator if you plan on bumping full tilt for more than 20-30 seconds at a time.
