DMM won't come on
N/A
I'm trying to set my gains properly for the first time with a DMM. I burned a CD with several test tones on it. The first one I'm attempting is a 1KHZ tone for my ID Q700.2 amp. I set it on repeat, disconnected the speaker terminals and set the DMM to AC Volts. I first put the positive and negative leads in the amplifier speaker terminals, and nothing came on the DMM. I tried connecting the leads to the end of my speaker wires, and still nothing. I tried everything, from disconnecting the RCA cables to keeping the speaker cables in the amp while I put the DMM leads in the amp.
I have absolutely no idea what to do. I've watched several videos, along with reading all over the place and I have no idea how to fix my problem. If anyone has any info please let me know.
Instead of groaning me maybe you should ask what DMMs I have.
Both of my DMMs don't have interchangeable batteries.
no they do...there will be screws on the back or something undo them and add new batteries...never ever once ever seen a dmm that u couldnt change batteries out...**** even my 10 walmart one has interchangeable batteries
Would you like a picture? And yes I'm the "stupid **********" because I spell like a moronic 14 year old.
take a picture but im telling u undo the screws in the back of the dmm take it apart and there should be a place to put in new batts.....i highly doubt there is any dmm on the planet that doesnt have interchangeable batts man...there not disposable cameras....just do like i said and tear it apart
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
889
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
359
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
N/A
nateberrier
    May 18, 2024
    May 16, 2024
