Double negative and postive outputs?! Plesse help...
My first system was an Fosgate 18 ran off a 4 channel American pro amp...I had a set of pyramid 6.5 coaxial in the front doors and ran it off a disc man with y's straight into the amp...I'm pretty sure it sounded like azz but I thought I was cool sh!t 🤣🤣🤣 all in a crappy 82 thunderbird
My first System was a Road Master HU, a Road Master EQ that came with a set of 6x9s,and I splurged and bought a set of Sony 2 way 6x9s,from a Kmart that I put in myself in an Ugly Azzed 66 Straight6 3 on the Tree longbed Chevrolet truck. Was Loud though 😁 😁
They are Available, as several others are. I am moving and Have picked what I want to keep. I have a Pluto VII just as clean not pictured also a couple Volcanos, and 30+ other amps
How much for the vii, vulcan and also the volcano? Damn man... I might have to work overtime next week.
With Hifonics you must use both sets of terminals at 1 ohm. I made the mistake of thinking it would be ok to just use 1 set on a Brutus BRZ 1700. I originally used both terminals but when I built a new enclosure I set it up with only one set of wires coming out. As soon as I powered it up and started tuning it it smoked. Other Amplifiers can be ran at 1 ohm using only 1 set but I do not recommend it with Hifonics just from personal experience.
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
821
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
9K
Denial-
CarAudio.com Recruit
Denial-
Pa
audiobaun
    May 18, 2024
    May 18, 2024
