Double Tweeter Bracket
Random4thGuy
Alright so recently I installed (2) 3.5" neo midrange woofers into my dash, problem is, I somehow managed to install them so they are not centered with each other (Two images below). Stupid, I know. Now at the same time, I have to find a spot for (2) 25mm silk-dome tweeters. So I was wondering if it's possible to fix the mistake and find a spot for the tweeters on the dash using a bracket. A bracket that would fit both the 3.5" speaker and the 25mm tweeter. Then I would be able to move one of the speakers upward to match the other speaker, finally have a spot for the tweeter, and cover up the leftover gaps using the bracket. Is there a bracket (or speaker pod or smth similar) that would be able to fit both speaker and tweeters? If not is there a bracket that would be able to cover up my mistake? Then I'd need a separate mount for the tweeter though.
Plenty of guys 3d prind adapters these days but pods while doable acn be more difficult.
Valicar stugartt makes excellent speaker pods but as far as I know ha doesn't do doubles. That said he was highly receptive to making a set for a tweeter he didn't already have once I asked so he may one off you a set. Just be prepared for it to be $2-300
True, I just can't seem to find any good ones 😭- At this point, I'm just trying to find one that can house a 3.5" and 25mm tweeter on the dash
This type is made as a base that would need work for a finished product. When you look it up in eBay, you will get other recommendations that may be more to your liking. As for covering the holes, you can use a dash mat.
I've purchased from that guy, wasn't too long, around two weeks delivery not bad. I also had some 1L pods printed for my Karma Aspect 3's. Stuffed them with Reonix fiber matt and they now can play down to 250-300 hz at rated power which one can only really do if the correct sealed environment is observed.
They came with 4 different mounting options too.
I need to have Bob make me a couple of the laser inserts for the m3carbons
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
9K
Look at the JVC brand. I have an older unit with a removable face plate. Model KW-AV61BT. Contact Crutchfield.com support for some current...
Random4thGuy
Random4thGuy
California
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
