First system
No that is not a good build. Let us know your alt size and age of battery up front. Also how much space you have for the subs because the box makes the subs.
A grand. I'm just looking for something that sounds good and hits a bit.
You can definitely do a he11 of a lot better with that much dough. I'd get a nice used deck, there's some killer ones on the classifieds here for around 100. There's plenty of good power wire for sale cheap here, too, although some knuconcepts or audiotechnix cca 1/0 would be fine and isn't expensive at all. Get enough to do your big three, and a lil extra just in case. Get some ring terminals off ebay. Rca's are everywhere for under 20 bucks. That gets your h/u and wiring out of the way for less than $250. 750 for subs, and amp will get you something pretty decent here, too.
I kind of already got all the equipment for this setup. I've got all professional wiring and I'm getting it all hooked up by a pro. I also had to get a special malibu kit for the information system. So basically I'm asking if I'll be disappointed. Any further feedback or tips would be awesome. All brand new everything.
you won't be disappointed til someone with a pair of obsidian 12's and audiopipe ASPM 1300 blows u doors off...and to know they spent only $400
---------- Post added at 10:25 PM ---------- Previous post was at 10:25 PM ----------
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
452
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
873
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
909
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
DatAudio
DatAudio
Michigan
DatAudio
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
