FS: 3 sets of Vibe audio SPACE 3D midrange/tweeter/3-way xover set
BNIB
[*]3D Design of midrange and tweeter combine to produce 360° sound
[*]High fidelity esoteric aluminum midrange cone
[*]PU dualroll surrounds
[*]1-3/4" (45mm) Midrange with 0.15mm high fidelity alloy cone
[*]1-1/2" (38mm) Silk super tweeter
[*]4 ohms impedance
[*]3/4" Voice coil size
[*]Separate 3 way alloy 12 dB per octave passive crossover
[*]Mechanical thermal unity for increased heat dissipation
[*]0-3 dB Tweeter attenuation
[*]Alloy gasket made from high grade machined aluminum
[*]Neodymium magnet structures
[*]Top-mount depth: 1-1/4"
$90 each shipped
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)).\
BNIB
- Space 3D Midrange and Tweeter System
- Power Handling:
Peak: 420 watts per pair / 210 watts each
- RMS: 140 watts per pair / 70 watts each
[*]4 ohms impedance
$90 each shipped
