FS: JBL 1201.1 mono amplifier
  • 3
donpisto
SOLD!
JBL 1201.1II mono amplifier
Mechanically, the amp is in perfect working condition. Physically, not the greatest. If the amp isn't visible, no problem. Smoked see-through glass does have a scratch. The grey part can be repainted to improve the look a lot. It is missing one screw, easily replaceable. I'm selling because I'm done with audio for a while.
•787 watts RMS x 1 at 4 ohms (1,114 watts RMS x 1 at 2 ohms)
•optional internal neon lighting (accommodates Street Glow AN9 tubes or equivalent, tubes not included)
•variable low-pass filter (32-320 Hz, 12 dB per octave)
•variable bass boost (0-12 dB at 50 Hz)
•MOSFET power supply
•preamp inputs and outputs
•CEA-2006 compliant
•fuse rating: 40A x 3
•1/0-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•18-11/16"W x 2-3/8"H x 12-5/16"D
$145 + shipping
Shipping will include insurance.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
donpisto
donpisto
Los Angeles, CA
dragnix
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
