SOLD FS JBL a6000GTI
MURFS_HOE
Well I know I'm new on here, but just like the title says trying to sell my 6000gti works perfect no problems at all.I've run 4 cvx 15s on this amp for about 6 months it was installed in my tahoe
Spec
Power Output 2600 Watts RMS x 2 channels at 4 ohms
and ≤ 1%THD+N
8110 Watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1%THD+N
7400 Watts RMS x 1 channel at 1 ohm,
Signal-to-Noise Ratio 65 dBA (reference 1 Watt into 4 ohms)
Dynamic Power 6854 Watts at 4 ohms
Effective Damping Factor 6.39 at 4 ohms
Frequency Response 10Hz to 270Hz (-3dB)
Maximum Input Signal 8.5V
Maximum Sensitivity 250mV
Output Regulation .2 db at 4 ohms
Dimensions (H x W x D) 6-1/2" x 29-3/8" x 23"
The amp has some scratches on it and I still have the box crate if you have any questions just ask PRICE $1800OBO
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
MURFS_HOE
MURFS_HOE
Oklahoma City
MURFS_HOE
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
