SOLD FS: JBL P1222 $135 shipped
  • 7
nismos14
Jersey
1. Product:
JBL Power Series P1222
2. Specs:
General
Power Handling, RMS 400 Watts
Power Handling, Peak 1200 Watts
Sensitivity 97dB
Mounting Depth 6-3/4"
Cutout Diameter 11-1/16"
Impedance Dual 2 Ohms voice coils can be wired to deliver either a 1 ohm or 4 ohm load
3. Description/Condition:
BNIB
12" (300mm) Plus One® (patent pending) Dual-Voice Coil Subwoofer
Kevlar-impregnated paper woofer cones - This combination has been chosen for its high strength-to-weight ratio, and is formed using a proprietary manufacturing process. Besides improved transient response, this cone adds stiffness to relieve stress concentrations that may accumulate at the base of the cone under high power and high-pressure applications.
Plus One (patent pending) woofer cones - JBL has taken its incredbile Plus One cone technology into the world of subwoofers. Each Power Series sub features more cone area than that found on competing subwoofers of the same size. This increase in cone area delivers an audible increase in bass output and efficiency.
The JBL P1222 features a proprietary die-cast frame that ensures that the motor structure stays centered in the voice-coil gap, ensuring long-term reliability and durability.
Stitched-in tinsel leads are used to greatly enhance reliability and eliminate audible tinsel lead slap.
4. Price: :
$135 shipped
5. Pictures:
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
nismos14
nismos14
Jersey
nismos14
