SOLD Fs: Jbl px600.2
  • 1
donpisto
SOLD!
JBL PX600.2 2 channel amplifier
Specs:
692 watts, Power Series 2-Channel amplifier
RMS Power Output:
4 Ohms: 180 watts x 2 chan.
2 Ohms: 290 watts x 2 chan.
4 Ohms Bridged: 663 watts x 1 chan.
Full MOSFET Power Supply
"Direct Connect" Terminal Block Allows for 4 or 8 Gauge Power Wire
Die-Cast Aluminum Chassis with Top Plexiglas Viewing Window
Variable High-Pass / Low-Pass crossover (32-320 Hz)
Selectable Crossover Slope (12 / 24 dB)
Dynamic Bass Optimization (DBO) Subsonic Filter
Preamp Outputs
CEA-2006 Compliant
S/N Ratio: 79.5 dB
Dimensions: 12-1/4"D x 17"W x 2-9/16"H
I never used this. Bought it off a forum member that said they never used it/slightly used it. Can't recall it's been way too long. It's just been sitting and I won't be installing speakers up front for a while so no need for this. I did have it wired up in my trunk, but no speakers were ran through it since I didn't get to installing them.
$160
Shipping is extra. I'm located in Los Angeles (626 area) for local pickup
Got refs, can't remember all, been a while. But tc3k101 can vouch. I know he's still a car audio ***** while I got out the business.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
donpisto
donpisto
Los Angeles, CA
donpisto
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
