General questions about LOC
  • 1
I am no expert in car audio, but I have had my fair share of aftermarket stereos. From a simple passive LOC/amp/sub setup to full system upgrades.
My first setup was a basic passive LOC, connected to an amp and sub. I upgraded piece by piece until I had some door speakers, and then upgraded a head unit. Switching from my stock '98 toyota head unit to a hand me down single din JVC from a friend changed the SQ so much. I then upgraded to a full kenwood system, new headunit, 4 channel and monoblock amp, 4 components and 2 12s. Best system I had had up to that point.
I had to get rid of that car and the system, and ended up driving a '00 Lexus RX300 with the premium sound system, when I went to try and upgrade this system I found out that you cannot change out the HU for an aftermarket system without losing complete functionality of the center dash. I had to settle for a cheap passive LOC once again, and the sound quality suffers in the subwoofers.
I have never used an active LOC such as an LC2I, and am currently looking at investing in a new car but am weary of getting another car with the "premium" sound system and not be able to modify the way I want/to the quality I want.
I am assuming the LC2I still wont perform as well as a headunit with preamp outputs, but I cant say for certain. Can someone explain the differences please! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I am trying to determine which would be best; getting the base model of the car with the changeable head unit but missing a lot of other features I would want from the premium models (heated seats/automatic climate control/automatic lights etc.), or if getting the premium models and attaching a LC2i (or similar) would have comparable sound quality, I know I do not like the passive LOC, so thats a moot point.
tl;dr Trying to learn the difference between passive and active LOC, versus a headunit with preamps and what will give the best sound quality, and if a new HU vs an LC2i would be comparable in sound quality.
time alignment is not the same as volume. Time alignment is usually only needed when you have an amp or multiple amps, and one has a delay. I...
Looks like it's wire it either 4 or 8 ohm 🤔
4
844
Okay. Thank you so much! I will run individual power / ground wires to each amp. If the front of the car has no dedicated spot for tweeters, what...
875
You will need distribution blocks for the amps I would run 0 gauge to the blocks and 4 gauge to the amps. For the head unit I would us one that...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
aspain89
aspain89
Mission Viejo, CA
aspain89
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
