I'm gonna be running one HDC3 12. I am wondering what people have ran on just one of these things. Are they under rated like sundown subs? My current plan is a skar rp2000 at 1 ohm (or .5 ohm idk).
Yeah we will see. If this isn't loud enough then I'm walling itUnless you are going for every last tenth on the meter, that skar amp will be plenty.
You will get 1k out of that skar clamped at best. Look at 2 to 4 ohm power if you account box rise because that is what you will see wired to 1 ohmOk that's about what I was thinking. I'm going to be just a tad short on power... The skar rp2000 clamps 2250 at 1 ohm at 14.3. So with box rise ill be clamping between 1400 - 2000 most of the time. Wish I could run a 2500 watt amp but my alternator will only be 220a
Did you have any issues with that 2200??I had a soundqubed 2200 on one HDC3 then when I got my soundqubed 4500 I put it on it at 1ohm and it did just fine with the 2200 but the 4500 it got stinky fast. It was a copper coil.
Nope set the gains and fed it the juice and it was happy.Did you have any issues with that 2200??
http://www.caraudio.com/forums/amplifiers/631351-soundqubed-2200-1-shutting-down-3.htmlNope set the gains and fed it the juice and it was happy.
