HDC3 power handling?
I don't think they changed it much vs the older hdc3 but 2000 for copper coil 3500 for aluminum
I've seen 4K per aluminum before with great results
Ok that's about what I was thinking. I'm going to be just a tad short on power... The skar rp2000 clamps 2250 at 1 ohm at 14.3. So with box rise ill be clamping between 1400 - 2000 most of the time. Wish I could run a 2500 watt amp but my alternator will only be 220a
You will get 1k out of that skar clamped at best. Look at 2 to 4 ohm power if you account box rise because that is what you will see wired to 1 ohm
I had a soundqubed 2200 on one HDC3 then when I got my soundqubed 4500 I put it on it at 1ohm and it did just fine with the 2200 but the 4500 it got stinky fast. It was a copper coil.
Did you have any issues with that 2200??
I sure did. Nostalgia is what brought me to this website, wondering if it still existed. I can still name some of the people and describe some of...
198
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
557
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
412
Based
Based
Louisiana
ncdrtyhoe
    May 18, 2024
    May 18, 2024
