HO Alternator Acceleration Spike: Cutting my Subs
mc71
Ever since I had my Mechman 240a installed (Nov 2014), a quick 16+v voltage spike occurs when I accelerate after idling (at traffic lights & stop signs). It throws my amps into protect mode a few seconds…mostly my AB 4480.1. The heater blower quickly surges, any dome lights on quickly flash brighter, etc. Once I’m in motion driving, the voltage stays around mid-14v, idling is around 12.8-13.5v, but if I'm sitting at a stop light or intersection, then step on the gas, the voltage jumps, my sub amp cuts out (occasionally my 4-channel amp too). The gains can be turned down, the amps can even be disconnected & I'll still see the spike with a DMM on the amp cable (currently I just keep a volt-meter plugged in my cigarette lighter).*
My battery keeps a good charge 12.8v (13.1v after a full recharge). My wiring & connections are solid. I've switched back in an old sub amp & same thing happens (w that amp, the cut out time is shorter but still..). Sometimes if I accelerate slowly I can keep it from spiking, but that gets more difficult once the car warms up.*
I've taken my car back to the shop that installed it (Mercury Mariner alts aren’t an average diy install) to check connections, belt slipping etc. And 2 other shops specializing in electric, they both ran tests & said the alt “seems” to be ok (one shop mentioned "though it idles low"). Both shops saw the 16+v spikes on their tests & said (paraphrasing) "it happens for a millisecond, then the PCM takes over….it just doesn’t catch the first millisecond” *
Mechman response:
"PCM controlled*Ford systems cannot respond quickly enough to the radical change in output (due to the unit being a high output piece) as you accelerate the engine.*This is a common occurrence with any PCM controlled Ford unit. *The spikes should be brief enough that they do not damage any electrical equipment in*the vehicle. *You can also add more battery capacity to reduce the amplitude of the spike. *Usually it is only noticeable on vehicles with small battery*banks and high capacity alternators."*
[While that nugget of info is helpful AFTER my purchase.....if the PCM ultimately regulates the voltage, why put regulators in an alternator custom-built for that car? And why would those regulators EVER let the alt produce 16+ volts? (surely the PCM isn't requesting it).]*
I don't know if it matters that my overall voltage meter level also constantly changes...…much, much more than when I plug my meter in a friend’s (oem) car. His voltage almost never changes & stays in the 14.1-14.2v range. Mine constantly changes, usually averaging around 14.3 on the highway, but still constantly changing, sometimes anywhere from 11.8-15.5v, certainly when pumping music….but even when idling w no power accessories on. The shops don’t seem too alarmed by this so I’m not getting too uppity about it. I’ve sent video clips of my volt meter to Mechman & they’re not too alarmed either. Just thought I’d mention. I can post the clips if needed.
Mechman offered to have me send it back for them to test. But like I mentioned, Mariner alt install ain’t that easy. It's located under the car, buried behind other parts, youtube tutorials call the swap a “pain in the ass”. Just having the Mechman installed (also upgrading cables) was $500. Now the lowest quote to swap it out is $300 (so aka $600 to have a $349 alternator sent in for repair).*
Neither shop tested the actual internal regulators/diodes…..they probably could, for another $300 + bench testing time. But briefly describing my issue to various people with various level of car knowledge (not necessarily with HO alts) has certainly been met with “sounds like a bad regulator” more than once.
So now I don't know what to do, I’m considering several options but can’t decide which is best (if any)
1. Buy 2 new batteries. I currently have an XS Power D4800 (815 ca) purchased 6-7 months ago, it's the only model their website says fits my car, for what that's worth. It’s rated for systems up to 3000W (both amps’ RMS would be under that….their fusing = 170amps). Ordering 2 (to be identical same-age) D4800's is roughly $600. *
Btw, I recently tried an odd dual-battery experiment adding a spare AutoCraft Gold battery (745ca) to the D4800 (815ca). The AutoCraft was brand new & the D4800 was fully charged, so I figured at least I'd try hooking them both up for a test (then unhooking right after). It initially worked & stopped my sub amp from cutting out...but after I drove the car a while, it would eventually cut out again if I wasn't gentle while accelerating. I realize the AutoCraft battery isn't big & heavy like the XS Power...but since they both have semi-similar "ca" values, part of me wonders if even 2 D4800’s would be less than 100% reliable solving this problem.
(I barely want to mention that I own a Precision Power 10F capacitor….it’s not hooked up….it didn’t stop the amp's protect mode when I tried it. But I’m thinking about hooking up the 2 batteries again & adding the cap as well, just to experiment. I’ve read that more "separate" power banks are better for smoothing out voltage. But just $.02, I did sorta think the sound seemed more “present” when I had the cap hooked up.)
2. Get a different alternator. I emailed Michael Singer about my problem (which he seemed familiar with) & he mentioned building me a "6-phase design, voltage regulator w twin rectifiers, high pole count rotor, 2 stators". Could this build make a difference? (assuming the Mechman alt is working as “expected”)? *I don't know much about alternator parts at all. But certainly*before I spend $600 swapping alternators, I'll just buy a different alternator & swap once.
3. Change amplifiers (to analog....mine are both hybrids). I'm wondering if digital/hybrid amps are more sensitive than analog. They sound better than my old Alpine amps (which sounded good) but my analog MRP-F250 never cut out during the spikes. My current amps match my drivers well (still wanting 1 more JBL mkii to run the 4480.1 at .75 ohms). Ultimately I know I shouldn't have to switch them & I'd always worry about popping subs.
4. Tweak PCM software (increase idle speed). Seems like a huge challenge if even possible.
5. Smaller pulley (although as the shop that mentioned the idea said "it's already pretty small"). I doubt this is the answer too.
I'm so tired of turning down my music at every stop light (& I live in a downtown area)...
Any input would be appreciated.
(Sorry for the post length)
I might have missed it it but did Mechman offer to make any changes to your alternator to avoid the problem in the future? If so, I know its gonna ****, but I'd give them the chance to make it right. If not , sell it and buy a singer.
They said I could send it to them to test it (& it's under warranty if anything's wrong). But every description I give them basically is met with "well that happens because all Fords have a PCM". It's never "gee yeah, that's odd". My problem is the $300 auto shop visit it will take just to get it to send to them...which is really $600 if I want it put back in (or buy another alternator to swap on the first visit). Mercury Mariners are like Ford Escapes, the alt's under the car & a ***** to get to.
I'm really curious if anyone thinks the difference in the Singer build would cure the spike if the problem is: Ford's PCM's don't play nice with aftermarket alts.
Singer wrote me "I show your stock alt to be pcm controlled so I assume mechman made you one that is self exciting (does not use the stock plug?) Typically the one wire regulators are known for that. I offer 6 phase options in a direct bolt in design for your application".
I listed the basic specs he gave me in the OP. I don't know a lot about what they'd mean, but he explained "Basically this means everything in the alternator is doubled up (it is built on the concept of two alternators inside of one case)".
Would that prevent spiking if the cause is Ford's PCM's just don't like aftermarket alts?
You & I might be only ones thinking it lol. But following up, I did try my "battery + battery + capacitor" parallel idea last night & it actually fixed (bandaided) the problem! I drove around about 20-30 minutes & tried plenty of hard accelerations & wasn't able to make my amps cut out. So I guess there's a thumbs up for having several power sources in a row vs one big one.
I'm still not loving having an alt that spikes (especially knowing the company's unsurprised it'd happen). But I'm starting to see I sorta bought an HO "light" alt (if the insides could've been doubled with a different model)....$349....so not the most expensive alt out there, but I would've paid more. I bought the only model Mechman offered for my car, so I just chose the wrong company.......jus sayin.
I guess now I'm leaning towards buying 3 XS Power D975 batteries & that'll keep me bandaided. And happy having them.
I'd still love any input or comments about anything I OP'ed. But I wanted to follow up..
Send it back my singer did the same. But mines not PCM controlled. Mike send me a sense lead adapter $40 problem fixed. Stabilized the voltage. And no battery light Mine would actually go up to 16.4 on take off. Btw
I just got my mechman 270a alternator in. I have a escape which is basically the same suv. Which engine do you have ? Do you have the room for a D6500 XS or even bigger.
I have a 3.0. My battery tray is about 8x11 so I don't think that'd fit. I'm thinking about 3 D975's (2 sideways in tray & in back).
Did you install it yourself?? What was your install cost?
Mylows10 That's the biggest thing is the quotes any shop gives me just to touch my alt.....I would do it myself if I could. But any YouTube video I can find has so many steps just to get to the alt....I always give up halfway through (& I read & watch tutorials a lot)
---------- Post added at 01:17 AM ---------- Previous post was at 01:16 AM ----------
One in back
Sorry I should of been more clear. My alternator just came in, probably install it this weekend or next. I have the 2.4 in mine the alternator is not hateful to get access to it. I also have a D4800 up front, plan on buying the D6500 for the back or 2 more D4800 batteries.
Can I ask what year escape? I didn't realize 3.0 would make a difference.....but I know whenever I call any shop asking for estimates...there's always the same tone they get once they look up my car like "yeah....that's not a small job". I had 2 appointments just to spend the $300 to have shops put back my oem....but first run tests to see if they can see anything wrong, to see if it's worth the $.....they've both said it didn't look faulty except the quick spike....then looks normal. So both times left it in.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
910
I don't have one...but I check my voltage with a dmm once a week or so
12
910
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
mc71
mc71
Columbus, OH
adulbrich
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
